Old 01-16-2017, 05:24 PM   #58 (permalink)
josemapiro
Hi skybolt
Originally Posted by skybolt View Post
How would you like to use it? Would you prefer going to the head unit, or more like the example version that used a built-in screen? I can show you how to make either one.
I do not have a definite idea of how it should be, initially I thought that it would be enough to connect an LCD to the Arduino and with the change of the code it is up and running,
but said that Arduino has with video, I have no idea Of what will be better.
I liked to replace the 2x16 LCD which is in operation in the MPguino for a graphic LCD more modern, the 2x16 LCD works great but has a more old-fashioned image, but this required major changes to the code which is out of the question.
Thanks
José Rodrigues
