Old 01-16-2017, 06:04 PM   #36 (permalink)
t vago
MPGuino Supporter
t vago's Avatar
iNXS - '10 Opel Zafira 111 Anniversary
Suzi - '02 Suzuki Swift GL
Did some more work on the deep sleep function. I believe I have something that will work, and am going to test it tonight.
Considering re-writing the ADC routines to save even more power during idle mode, when MPGuino is patiently waiting for the next injector pulse or VSS pulse or button press. Right now, for those configurations which require ADC (mainly the 5-position Parallax switch or the 5 analog buttons or the Chrysler MAP sensor input), the ADC is pretty much sampling all the time.
This won't affect those of you who do not use these things right now. However, in the future, it may affect those of you who want vehicle battery voltage readings or coolant temperature or other analog readings.
The Following User Says Thank You to t vago For This Useful Post:
josemapiro (01-17-2017)
