Originally Posted by t vago
This won't affect those of you who do not use these things right now. However, in the future, it may affect those of you who want vehicle battery voltage readings or coolant temperature or other analog readings.
I think that this inactivity only happens after a certain time without activity in the injectors, VSS or button, if it is thus who wants to consult the voltage of the battery or any other reading, when using the button activates the system again, leaving all the information again available.
Thanks
José Rodrigues
