Old 01-17-2017, 10:19 AM   #31 (permalink)
hayden55
Sport Utility Prius - '10 Toyota Prius II
90 day: 52.98 mpg (US)
300k Sequoia 4WD - '01 Toyota Sequoia Limited 4wd
90 day: 20.19 mpg (US)
Going to spin the wheels and check for dragging pads, tires are at 50psi, had car aligned when i bought it but could be better with shimming the left rear hub to get rid of that -.28 toe, and every other wheel had-.02 toe. Will check my resting voltage of the battery, and will take the battery to be tested at the parts place. Muffler tip wasn't discolored with soot so i guess it's doing okay.
"I feel like the bad decisions come into play when you trade too much of your time for money paying for things you can't really afford."
The Following User Says Thank You to hayden55 For This Useful Post:
redpoint5 (01-18-2017)
