Old 01-17-2017, 02:22 PM   #53 (permalink)
cr45
surface area ratio
This equation can be used to calculate the ratio of piston crown and cylinder head surface area for one engine compared to another.
n - number of cylinders
V - engine capacity
e - bore to stroke ratio
Surface Area Ratio = (n2 / n1)^0.3333 + (V2 / V1)^0.6666 + (e2 / e1)^0.6666
If comparing 2 engines that have the same capacity and bore/stroke ratio then the equation simplifies to (n2 / n1)^0.3333
Using this equation to compare the piston crown surface area of a 4 cylinder vs a 3 cylinder engine we get
ratio = (4 / 3)^0.3333
ratio = 1.1006
Hence a 4 cylinder engine has 10% more piston crown and cylinder head surface area compared to a like sized 3 cylinder engine. This gives the 3 cylinder engine a nice head start in the fuel economy stakes.
The Following User Says Thank You to cr45 For This Useful Post:
Ecky (01-17-2017)
