Old 01-18-2017, 12:12 PM   #161 (permalink)
Stubby79
Stubby79's Avatar
Firefly EV - '98 Pontiac Firefly EV
90 day: 107.65 mpg (US)
Little Boy Blue - '05 Toyota Echo
90 day: 33.35 mpg (US)
BlueZ - '19 Nissan 370Z Sport
90 day: 17.19 mpg (US)
Turtle
Weather has finally warmed up...and I've finally stopped working on other projects to see if the battery(and therefore the motor) perform better above freezing.
Yup.
She was managing to maintain 400a while accelerating in 2nd at 5 centigrade, instead of barely above 200a at -2c to -5c.
Take the effect of temperature...
And then add it (or more like multiply it) to the effect of heavy discharge...
...and you end up with your motor controller trying to protect your batteries from over-discharge.
Wouldn't be an issue with a higher voltage battery pack (72v at the moment)
Wouldn't be an issue if it was room temperature outside.
Wouldn't have been so off-putting if I had been sure that was all it was!
So, since she was a good girl, and it was warm enough out, I opted to rig together my little charger and give her some juice as a treat:
Good to see the Link10 can read finer amperages through it's "prescaler". Would suck if it couldn't read the charging properly...
Side note, the potential heart of a bigger charger that I won on ebay for cheap has arrived. That will be a project for down the road, though.
The Following 2 Users Say Thank You to Stubby79 For This Useful Post:
Daox (01-18-2017), thingstodo (01-18-2017)
