Old 01-19-2017, 10:24 AM   #166 (permalink)
Stubby79
Stubby79's Avatar
Firefly EV - '98 Pontiac Firefly EV
90 day: 107.65 mpg (US)
Little Boy Blue - '05 Toyota Echo
90 day: 33.35 mpg (US)
BlueZ - '19 Nissan 370Z Sport
90 day: 17.19 mpg (US)
Shouldn't be too massively hard to create a circuit to check the temperature of the pack, and if so activate a relay to power the charger and enable it to charge. If it doesn't pass the temperature check, it activates another relay to a heating pad of some sort to heat the pack up above freezing.
It won't be difficult, IMO. I'll set it to 5 degrees, just to be sure. And, if I've gone that far, I'll probably have it set on a timer to pre-warm the battery before I go to work, so I don't experience the voltage/capacity drop in the winter.
