Old 01-19-2017, 07:19 PM   #146 (permalink)
oil pan 4
Originally Posted by tf4624 View Post
works fine in carb vehicle... you have to modify the computer reading oxygen level in the car to see a change an also sometimes the MAP sensor too.
Oh so you trick the engine into running the engine lean, no wonder it works. Sounds like you could skip the hho generator and just run lean. Lean burn gives around a 20% boost to fuel economy.
Anyone who believes hho works is delusional.
The Following 2 Users Say Thank You to oil pan 4 For This Useful Post:
t vago (01-19-2017), Xist (01-20-2017)
