Old 01-19-2017, 07:34 PM   #147 (permalink)
tf4624
Eco of course
Oh so you trick the engine into running the engine lean, no wonder it works. Sounds like you could skip the hho generator and just run lean. Lean burn gives around a 20% boost to fuel economy.
Anyone who believes hho works is delusional.
you substitute fuel with HHO..
if you lean to much without substitute you will cause damage.
