Old 01-20-2017, 03:32 PM   #65 (permalink)
skybolt
deviant
s2k - '02 Honda s2000
Can't do JSON output on 0; compile error:
Code:
sketch/main.cpp: In function 'void pushSerial0Character(uint8_t)':
main.cpp:5895: error: expected primary-expression before ')' token
  while ((UCSR0A & ) == 0); // wait until USART0 data buffer is empty
exit status 1
Trying to debug as best I can (or set correct parameters if I've set them incorrectly to generate this error.
JSON output on serial1 does not generate this error.
The Following User Says Thank You to skybolt For This Useful Post:
t vago (01-20-2017)
