Dia duit
I work on wind turbines they have large capicitors to even out the grid load they really do have serious storage potentional power in them what you need is a way to charge them up take out the regulator of alternator and put a higher capacity one in say 100volts instead of 14volts I always thought these would be a great addition to a ev battery pack if you watch the amp meter when the load changes it drains the charge from battery with a capicitors set up it would drain them instead of battery and you could extend range milage greatly
Over
