So i have this car that i was going to sell for a diesel which can be modified a bit better but it appears i may be stuck with it.
It already has LPG and currently my fuel cost is comparable to a modern gasoline car so it is not too bad to own.
What mods do you recommend doing on it to make it more economical?
Will water injection play nice with LPG?
I also plan on deleting the mirrors which are slightly broken at the moment.
I also plan on putting full grill blocks. I can spray the radiator with water to reduce the need for the fan as it can suck quite a bit of energy when it is activated.
Hot air intake, would that have any negative effect on using it with LPG?
What else can you guys think of? I know it is not the most economical to begin with.
This is what it looks like:
