Old 01-23-2017, 07:45 AM   #31 (permalink)
aardvarcus
aardvarcus's Avatar
Deep Blue - '94 GMC Suburban K2500 SLE
90 day: 23.75 mpg (US)
Griffin (T4R) - '99 Toyota 4Runner SR5
90 day: 25.43 mpg (US)
So yesterday I cleaned up and deburred the oil pan, wire wheeled the oil pan mating surface down to bare metal and sanded it with 1000 grit sandpaper. I scraped and cleaned the block and gave it a light pass with the sandpaper as well. I picked up some permatex sealant and pulled out one of the fel-pro gasket kits.
I put in the rear main seal with only a drop of sealant on each end per the directions. I decided to use the oil pan gasket with a light coating of permatex above and below it. I have read so much conflicting information on gasket vs rtv I just decided to go the belt and suspenders method. The army technical manual stated you could use both together, and the fel pro gasket kit instructions said to use a light coating of sealant with the gasket.
Anyway I snapped a few pictures during the process. Time to flip the block back right side up.
ID:	21220   Click image for larger version
ID:	21221   Click image for larger version
ID:	21222   Click image for larger version
The Following 2 Users Say Thank You to aardvarcus For This Useful Post:
skyking (01-23-2017), slowmover (01-23-2017)
