Old 01-23-2017, 02:39 PM   #33 (permalink)
cRiPpLe_rOoStEr
Originally Posted by teoman View Post
Just read that the new gasoline engines are supposedly compatible with E85, which has corrosive water and alcohol inside.
Most of the fuel injection hardware nowadays are compatible to E85, and the ethanol is actually more corrosive than water. Anyway, since in my country we use hydrated ethanol at a concentration of 96% by volume with the other 4% being mostly water, and that an ethanol-capable engine can still operate at a concentration of 80% ethanol by volume with the other 20% being water (seems inviting to run on homebrewed vodka not standardized to 40% alcoholic volume), it sounds like using hardware from a fuel system for the water spraying device won't get you in trouble as long as you avoid using tap water. Distilled water prevents electrolythic corrosion of the metal parts.
What water soluble oil/lubricant would not upset a diesel engine?
Alcohols, either ethanol or methanol, can be used to emulsify some lube oils and the water. Those castor-based oils used for competition 2-stroke engines are more likely to work since they're easily soluble on alcohols.
