Old 01-25-2017, 01:08 PM   #231 (permalink)
NoD~
NoD~'s Avatar
Frogger - '00 Honda Insight Gas Only (unHybrid)
90 day: 68.51 mpg (US)
Originally Posted by HyperMileQC View Post
Also for the grounds, be sure to check for the little power steering rack & pignion ground, its a little bit tricky to get to it but this ground is also very important. Make sure it is in good shape, on my two Insights it was broken and I repaired the grounds and upgraded it.
Is that ground important for the power steering or the engine? Mine looked OK at a glance, so I left it, but my power steering never worked, so I yanked that motor out and took out the worm gear (well worth it, IMO).
I did, however, build a new ground kit with I think 4awg power cable. Make sure you sand to bare metal @ the chassis at all your ground points if you want the best conductivity! I put some Nolox on these to keep corrosion down.
