The delete works fairly well even on a largish car like my Camry, if the lines are looped. I'd look into local laws though because after 6 months of manual steering (I gained 3 mpg highway), I got dinged at safety inspection for it since it's not set up as OEM. Spent $300 on all new lines and the high pressure one I got from Rockauto doesn't fit, threads are a little different. Toyota wants $700 for the one high pressure line. Not sure what I'll do at this point but if you are thinking of this, CHECK YOUR LOCAL INSPECTION REGULATIONS. I preferred no power steering myself though, kinda disappointed.
