Originally Posted by teoman
Dual fuel system, using both at the same time. Independent injectors if i remember correctly.
OK BUT I am looking a normal gas injector system AND a vapor system and considering using diesel as the fuel for the vapor.
I read somewhere that diesel made better vapor and with less junk and with lower temps to convert it to 100% vapor, but at the time I considered it out of the question and did not look into it.
Now a dual tank for each system is looking better.
So trying to find out about diesel again.
Rich
