It is for the EPS system I think but on my two insight both EPS worked with a broken ground. IMO they did not put a ground there for nothing so I just put one there because I know Insights can be strange with grounding issues better to have more than not enough haha.
Sanded all metal where the grounds connect and measured everything and all shows good readings, near 0 ohms.
Also, Daox, I hope changing your coil packs will stop your problem. I think I read that you changed the plugs so this is a good start that cant be bad, you surely indexed it so everything should be fine ignition wise. Have you also measured the gap of your plugs before installing them?
Trollinsight Modding Thread
2000 Honda Insight MT Silverstone Metallic #95 (CAN) 131K mi. 81.7 Lmpg
Best Tank : 100.06 MPG (US) | 120.2 MPG (Imp) | 2.35 L/100Km | 42.54 Km/L
Best commute : 130.8 MPG (US) | 157.1 MPG (Imp) | 1.8 L/100Km | 54.84 Km/L
Best Trip : 111.8 MPG (US) | 134.3 MPG (Imp) | 2.1 L/100Km | 47.53 Km/L
