Old 01-26-2017, 07:31 AM   #32 (permalink)
aardvarcus
aardvarcus's Avatar
Deep Blue - '94 GMC Suburban K2500 SLE
90 day: 23.75 mpg (US)
Griffin (T4R) - '99 Toyota 4Runner SR5
90 day: 25.43 mpg (US)
Continuing to plug away at this. I got the block back right side up and began scraping off the remnants of the intake manifold gasket from the engine and the intake. I would love to gasket and port match everything, but that is a later down the road project. The intake gasket has a good sized gap on all sides of the intake and head, but I did a paper traced overlay to compare the head to the intake and it was actually closer than I had seen in online photos, perhaps the GEP quality control has tightened that up a bit.
I did notice on the intake manifold there were a few casting flaws where there was a slight edge to the intake manifold that formed sort of a shelf. I chucked up a sanding tool in my dremel and ran it around the intake manifold ports on all sides. I intentionally didn’t really take any meat off, just got the casting flaws gone and smoothed it out just a bit.
The rest of the intake has a “sand” finish on the inside; I don’t think it is necessary since no fuel/air mixture is traveling through there, just air. I don’t know if I will smooth it out, probably another later project.
Anyway, some pictures of the intake “porting” work, notice the before and after of the runner with the worst casting flaws.
ID:	21231   Click image for larger version
ID:	21232   Click image for larger version
ID:	21233   Click image for larger version
ID:	21234   Click image for larger version
The Following User Says Thank You to aardvarcus For This Useful Post:
slowmover (01-28-2017)
