ScanGauge II installed above the speedometer. It's a little crooked in this photo, I adjusted it after and it's straight now. I wish I could have gotten its wire to go through the windshield defroster duct, but it didn't work out. I'll have to take apart the entire dash if I want to do that.
I also made a coroplast partial radiator block. It blocks a little over 50% of the radiator surface, probably like 60%. It looks beat up because it was previously a lower aero panel on the silver G1, but it wasn't the right size so it got damaged when it was used in that capacity, and I was tired of reattaching it every so often. So I sacrificed it to make this rad block.
I wrote the measurements on it so anyone else with a G2 Insight can easily copy it. It fits really well.
Like my G1 coroplast rad block it sits in front of the radiator with a tab on the top so you can easily remove it.
And I don't have photos, but I installed a dash cam, it hides in front of the rear view mirror, and is wired through the driver's side A-pillar down to an extra 12v socket I installed hidden from view behind the stock 12V socket.
