Old 01-28-2017, 11:47 AM   #9 (permalink)
cr45
If the compression ratio in the "air spring" cylinders were to be lowered I suspect that you might get a useful efficiency gain.
One way to do this might be to remove the inlet or exhaust valves and then block the port downstream from the valve.
Another option would be to fit pistons with a lower piston pin to crown height.
The lower compression ratio would allow one of the compression rings to be removed thus reducing mechanical friction.
