Thread: Hi everyone
Old 01-28-2017, 06:17 PM   #2 (permalink)
oil pan 4
It may sound backwards but put some kind of tunable fuel induction system on that motor. Even if it's a carb.
Tune it for lean burn.
I did this on 2 carbureted and it boosts fuel economy by about 20%.
Cross fire is kind of all around hated. Low horsepower, laggy throttle response and lack luster fuel economy.
A manual transmission is the way to go. My 1989 firebird has a 350 TPI, 6-speed with 0.6:1 top gear and 3.73 gears and it gets at least 26mpg if I can keep my foot out of it.
I am going to put a T-56 magnum in it with 3:1 first gear and 0.5:1 top gear and a ford 9 inch with a 3:1 or 3.25:1 gears. That should boost the fuel economy up a little.
Then the 350 might not have the torque to turn the wheels going down the highway at 1300rpm so u have a high compression 489 cubic inch engine to put in it.
