Old 01-29-2017, 02:14 PM   #70 (permalink)
skybolt
deviant
s2k - '02 Honda s2000
Originally Posted by t vago View Post
I am not able to duplicate this problem.
This appears to have been an intermittent (!) issue associated with my USB-C to mini-to-FTDI adapter. It is now functioning as expected.
Should the code have JSON output turned on even if there is no VSS pulse or injector pulse detected?
I assume you are not referring to sleep mode after not detecting speed/inj pushes for a set time? I can work around sleep with a periodic reset or extending the timeout period. If, on the other hand you leave it on all the time, and suppress output to save energy, then that would cause problems. How much energy is saved when suppressing output?
I can see the logic in not wanting to send output when there is nothing to send, and it is elegant, but it also seems to be a solution in search of a problem.
I have a work item to be tackled later -- setup over JSON. That would require constant output, but of course that could be addressed by
Code:
(if SETUP) {send_output;}
In other news, SUCCESS!! I now have a working arduino pro mini (3.3v, 8MHz) working, attached to a raspi shield containing all car-to-arduino circuits and arduino-to-pi pins. It's a bit ugly, but it works, and so I can now do in-car testing with the new code base and pi output. I've noticed the most recent JSON output isn't formatted correctly, I'll start working on that.
NOTE: I will post specifics later, but using VNC on the pi and my phone's hotspot allows me to project the 2nd pi (with the new code) to my phone, so I can view new and old back-to-back. I will post which pi-based VNC server I'm using -- which if you go this route you will want, as it a) projects the console, if desired; b) uses native authentication making it both slightly less insecure and easy to use, and c) works flawlessly with the official vnc clients.
The Following User Says Thank You to skybolt For This Useful Post:
t vago (01-29-2017)
