Originally Posted by skybolt
Note the "--------------"
CAUSE FOUND! When no fuel used (i.e. tank reset), calculates to --------. Cannot be read by pi.
Q: What's the precise sequence for tank reset? Once I'm on the tank reset screen, I keep getting "button pressed (hex value)". At that point it appears to be reset, do I just use R+L (normally setup trigger) to exit tank reset?
