Old 01-30-2017, 11:40 AM   #4 (permalink)
me and my metro
me and my metro's Avatar
Economy Saturn - '02 Saturn L200
Like Oil Pan 4 says it is a no gain ratio wise. Actually you will turn slightly higher rpm on the highway. Did your van ever come with a standard transmission? Clutch pedal stuff may be a pain to fabricate.
Back in the early 80s manufacturers used car based transmissions with a flipped 3rd gear to get overdrive transmissions. If you are not going to work your van like a truck you might look at a v-8 car transmission. It would have 5 usable gears with good rpm splits.
02 Saturn L200 5 speed- 265k miles
84 Gmc 6.5 na diesel K30 4x4, TMU
2006 Lincoln Navigator, 215k miles
