Maybe we can get MPGuino to take input from a smartphone, too (via the pi)?
Right now I'm working on how to deploy a sketch to the arduino from the pi -- FTDI is out (an extra board is undesirable, also don't want to collide with tx out); ICSP is out (don't want to have to add a capacitor and extra crystal), I think I can do it if I send a 0 (or low) to the rst pin. This would be first level of control from the pi/phone.
Should be easy to have the pi send signals to the arduino (such as A3, 4, 5 to ground). Long term (i.e. future plan with no idea of work involved) would be to scoop serial rx pin for string commands from pi.
Basically, the idea is to have any button press that actually resets a trip or writes a value to EEPROM, be a long button press.
Good plan, I'm sure you've had a number of accidental resets before putting long-press into place.
Code:
"subtitle":"drag stats: 0-30 MPH in 0.000 sec, 0-60 MPH in 0.000 sec, 0.000 sec to 0.000 mi @ 0.000 MPH, engine output 0.000 HP @ 0.000 MPH",
As you know this is scrolling off the screen to the right. I've given up trying to insert a BR or CRLF into the display text; I will toy around with moving some drag stats to the middle graph, leaving some at the bottom. Probably distance stats in the middle/mileage section, fuel usage drag stats in the 3rd section.
Code:
const unsigned int pAddressInjectorCount = pAddressRefFuelPressure + byteSize(pSizeRefFuelPressure);
const unsigned int pAddressInjectorSize = pAddressInjectorCount + byteSize(pSizeInjectorCount);
As near as I can tell, mS/Gallon is calculated/modified by numberOfInjectors. Why is this there? Is this for Chrysler compatibility? I've been going back to the old method of 1 injector and my old mS/Gallon. Fuel pressure and injector size appear to have no effect on my setup, is this for future hyper-precise calculations? Can I ignore this for now? If not, I have 650cc injectors, is the size (246cc default) the maximum or a different flow value?
Code:
scratchpad
BGLower
BGDSize
FE Filter
FE Time Period
What's the significance of these parameters?
