Old 01-30-2017, 02:21 PM   #218 (permalink)
oil pan 4
The biggest difference between cold starting a carb versus fuel injection in the cold is the fuel injection needs about 20 seconds for the exhaust manifold to warm up.
But most people remove the heat riser so they run like poop in the cold until they start to warn up.
With the thermostatic intake I can get mine to run a fairly consistent 16:1 or leaner air fuel ratio.
