Old 01-30-2017, 04:43 PM   #36 (permalink)
aardvarcus
aardvarcus's Avatar
Deep Blue - '94 GMC Suburban K2500 SLE
90 day: 23.75 mpg (US)
Griffin (T4R) - '99 Toyota 4Runner SR5
90 day: 25.43 mpg (US)
Oil Pan,
Stock the Suburban came with 4.10 gears, so I will be running them for a bit, but the eventual plan is to run 3.42 gears. That is the highest ratio I am aware of for the stock 10.5 14bolt/9.25 IFS differentials. With 6.34:1 first gear on the NV4500, taking off shouldn’t be a problem even with the higher 3.42 gear ratio.
Stock 4.10 with 0.73:1 overdrive and 31.8” tires equates to 1800RPM at 55 mph and 2300 at 70 mph. Stock 3.42 with 0.73:1 overdrive and 31.8” tires equates to 1500RPM at 55 mph and 1900 at 70 mph.
