Old 01-31-2017, 08:31 AM   #39 (permalink)
aardvarcus
aardvarcus's Avatar
Deep Blue - '94 GMC Suburban K2500 SLE
90 day: 23.75 mpg (US)
Griffin (T4R) - '99 Toyota 4Runner SR5
90 day: 25.43 mpg (US)
So last night I did the first of the prepwork for pulling the engine. First I got the batteries disconnected and out of there. Next I disconnected the air intake back to the turbo. I pulled the relocated PMD and extension harness. I pulled the stock skid plates and splash guards off the bottom front.
Next I started trying to drain the antifreeze, (without making a mess in the garage) but the drain port that you hook a hose to was pointing straight down into the lower radiator support, so no luck on that front. I started trying to siphon the antifreeze from the top radiator port, and got several gallons out. Ran out of time, but I will have to start pulling hoses off the bottom to finish getting the coolant out.
