Old 02-01-2017, 11:45 PM   #1 (permalink)
VWCw
VWCw
VWCw's Avatar
10 Jetta V - '10 Volkswagen Jetta
90 day: 34.76 mpg (US)
Stealth/Removable Grille Block (MkV Jetta)
Using $4 worth of foam rubber weather stripping, I made a pretty much invisible, completely removable upper grille block. This was for the MkV Jetta that I just bought, but the general design should work for most cars (esp. any with horizontal grille slots that aren't too far apart).
For my particular grille, I needed four sections that were 10" long and three layers of weatherstripping tall; and four strips a single layer high. If you're copying this for your Jetta/Rabbit, remember that the top slot is the air intake.
These are just squished into the grille slots, so should I ever decide to tow a trailer through Death Valley CA in the summer I can just pull them right out.
Now to track my engine warm-up time with some A-B-A over the next week.
ID:	21260   Click image for larger version
ID:	21261   Click image for larger version
ID:	21262   Click image for larger version
ID:	21263   Click image for larger version
The Following User Says Thank You to VWCw For This Useful Post:
mpg_numbers_guy (02-22-2018)
