Originally Posted by Aeroguy
As far as winglets are concerned, I believe you are referring to what are called endplates in terms of cars. There is a good example on Mulsanne's Corner and I have uploaded an image of one of the wings I designed (it has something similar to a NACA 4412 airfoil flipped upside down) and there end plates on it although they are built into the mounts. imgur. com/a/PhFcd (I don't have enough posts to post links yet).
I am having a hard time understanding what you are getting at with the wavy corners. Is there any way you could sketch something out so I could get a better idea. I'm not really knowledgeable enough to understand the acoustic side of aerodynamics. I've never really looked into it.
Will you be testing both wings and spoilers?
Will you be able to test combinations of both?
Yes, F1 cars have one type of plate at the wing ends because of regulations, I'm guessing you are exploring ideas outside of these restrictions - yes?
Just think if these fins below had been curved inward - the possibilities for down-force and stability with minimum surface area/drag.
Looking for 1963 Le Mans Panhard Cd blueprints
http://ecomodder.com/forum/showthrea...nts-33026.html
http://www.talkativeman.com/graceful...rbus_a350_xwb/
http://www.autodrome.fr/cd_panhard_l...64_english.htm
