Old 02-03-2017, 05:41 AM   #65 (permalink)
gumby79
gumby79's Avatar
little jona - '91 Dodge D 250 first gen cummins LE
Team Streamliner
90 day: 23.4 mpg (US)
Little Jona airo modded - '91 Dodge RAM 3/4 TON D 250 2×4 AUTO
Pickups
The Salted Hound Jenny. - '87 Dodge Ram 50/D-50 5sp 4X4
90 day: 20.24 mpg (US)
Jona Allison aero - '91 Dodge Ram D-250 Le
90 day: 20.76 mpg (US)
On the brushes would be purity Kangaroo proof.
Call in an order that is 3 bristles thick in a 45-60°angle. Each row counter the next.this will give some stability and stiffness. Im gussing with there 250mm (~9") bristles. they would be your desired 6" length . maby do 5 of eachV and U .
For V
Dump the air into the front brakes/wheel wells. ( a low pressure zone). Best would be to make the end an air curtain th direct the air around the front wheel. Fill the finder tire gap with the brushes on the front 2/3.
U shape
The chin would be back behind the bumper on a gental curve out to the tyer ~ 1/3 in from the outer edge With out air curtains. With them iirc it would lind up with the out side of the tire creating a low presure high velocity on the front of the tire.
. Park a truck pointed into the wind take notice of the bow wake . Try to mimic this natural shape, as nature is pointing the parh of least reassurance.
Like kach22i did hear.
http://ecomodder.com/forum/532983-post596.html
Thoughts I had what is goung to keep a kangaroo from sliding up the hood and coming through the windshield. A brush/ kangaroo garde made with airfoil shaped tubing. Adjust the angle of attack in loacal air( the loacal direction of air traval accounting for the bow wake . Not the direction of road travel. ) to move and accelerate the air in the direction most suitable for your shape. If dond right the Airfoils direction of lift will be forward. (Resulting in a negative drag coefficient?)
http://ecomodder.com/forum/showthrea...mk3-34517.html
Maby run both stiles U in frontto air curtains at 3"deep and V at 6"deep continued filling of the turbulent low presure wheel well. Even add a secondary air curtains from the V at the back of the tyer.
1st gen cummins 91.5 dodge d250 ,HX35W/12/6 QSV
ehxsost manafulld wrap, Aero Tonto
best tank: distance 649gps mi 24.04 mpg 27.011usg
Best mpg : 31.32mpg 100mi 3.193 USG 5/2/20
Former
'83 GMC S-15 Jimmy 2door 2wd O/D auto 3.73R&P
'79 Chevy K20 4X4 350ci 400hp msd custom th400 /np205. 7.5-new 14mpg modded befor modding was a thing
87' Hyundai Excel
83 ranger w/87 2.9 L FI2wd auto 18mpg on the floor
04 Mitsubishi Gallant 2.4L auto 26mpg
06 Subaru Forrester XT(WRX PACKAGE) MT AWD Turbocharged 18 plying dirty best of 26mpg@70mph
95Chevy Blazer 4x4 auto 14-18mpg
04 Chevy Blazer 4x4 auto 16-22mpg
The Following User Says Thank You to gumby79 For This Useful Post:
craysus (02-05-2017)
