Old 02-03-2017, 03:44 PM   #250 (permalink)
racprops
Originally Posted by RustyLugNut View Post
By your analysis and admission, neither is the Pogue Carburetor equipped car which pretty much followed the same formula to 200 mpg. Thus I expect you will desist from bringing up that device as an "example" of high mileage possibilities, in the future.
Xist bringing up the Shell Eco Racer as a parallel to the Pogue Experiment is relevant in that they are similar exercises. Most people who use the Pogue carb as a miracle device do not look deep enough into the experiment to realize it is impossible to separate the other variables that contributed to the 200 mpg end result.
I agree with you, I have not used the Poque carb as a point...I can see it could NOT produce such MPG in a real world car driven normally.
It at best could only produce a little vapor and at best given a small improvement in MPG.
There was no system to completely vaporize the fuel.
Rich
