Old 02-04-2017, 03:15 PM   #7 (permalink)
aerohead
how did you make
Originally Posted by dylman3 View Post
I am pretty sure I saw your truck on the site earlier and was inspired. How did you make yours? I do not have experience with any body mods yet, but I was thinking the same thing, and of how cool it would look if you put a 4" induction cowl hood scoop on top of a 2" flat Induction cowl hood. Or just a single hood with that layered look. Since I've looked on the internet for an hour with no such thing, I don't know if I have the same aesthetic tastes, or if its a bad Idea aero-wise, but I want to do something along those lines, just cant afford all that stuff.
I stripped the facings off of polyisocyanurate insulation board from Home Depot and pinned a foam 'skin' onto a foam skeleton,then fiberglassed all that in place,on the truck,using polyethylene drop-cloth as a release barrier.
I won't know it's effect until I can get to DARKO,so I can't even recommend it as a mpg-saving mod.
In theory it might improve the sectional density and pressure/velocity profile of the forebody,plus direct the air in the vicinity of the side mirrors at a lower local velocity.
I would not recommend this area for induction of any sorts.The forward stagnation point would be the place for that.
