Old 02-05-2017, 07:30 PM   #14 (permalink)
oil pan 4
I finely got to building my test stand and putting an alternator on it.
The alternator is a modern 150 amp output ACdelco DR44G, also the AD244 is almost the same. So it's not a small alternator.
Turning the alternator at an unrealistically slow speed of about 3,600rpm only took between 100 and 120 watts for the alternator plus belt..
A little less than what I expected.
Next I had a 4 inch pulley to put on the motor. The larger pulley should spin it up to 5,760rpm.
A bit more plausible for a usable speed but no where near cruise RPM. It only used between 120 and 140 watts to turn the alternator plus belt.
A minimum cruise speed is going to be at least 7,500rpm.
Edit: no field current. Just free spinning.
Daox (02-05-2017)
