Old 02-05-2017, 09:03 PM   #44 (permalink)
deejaaa
Not banned yet
deejaaa's Avatar
Blue - '03 Chevy S-10, LS
Originally Posted by aardvarcus View Post
Deejaa,...Is your 1993 a single rear wheel or a dually?
mine is single. can't check mpg right now. have a 30 gallon tank mounted in the bed and no in cab gauge. it's mounted on the side of the tank. i got a best of 20 when i was running mostly freeway.
i will get a saddle tank and sending unit after i start working the new job. will get them from a junker. can get both for about 40.00. i will use the bed tank as a siphon tank. when it runs dry, i will then use the gauge from the saddle tank.
that's the plane at least.
mine is about to go under the knife again. need to remove the valve covers to trace down a noise. a lot has to come off to get to them.
2003 S-10, 2.2L, 5 speed, ext cab long bed.
So far: DRL delete, remove bed mount toolbox.
