Originally Posted by teoman
Well, my idea was that, if you nebulize very hot liquid the droplets will also be very hot. When the pressur is relieved (droplets ejected from chamber) they will instantly vaporize.
Well there is the idea of vapor with a drop in pressure...
But I feel just heating the liquid will make vapor and the vapor will cause some pressure as does steam.
Letting it feed into a larger chamber will help finish the job as the pressure drops.
Rich
