Will your super heated gasoline vapor ignite the moment it sees oxygen?
If you have a gasoline engine that has injectors maybe you can build some kind of heated barrel with a checkvalve in front of it that goes in between the injector and block.
This way it will be full of vapor all the time and it will inject its contents once the injector fires a new pulse of fuel which immediately vaporizes pushing available vapor out.
