Old 02-09-2017, 08:11 PM   #24 (permalink)
gumby79
gumby79's Avatar
little jona - '91 Dodge D 250 first gen cummins LE
Team Streamliner
90 day: 23.4 mpg (US)
Little Jona airo modded - '91 Dodge RAM 3/4 TON D 250 2×4 AUTO
Pickups
The Salted Hound Jenny. - '87 Dodge Ram 50/D-50 5sp 4X4
90 day: 20.24 mpg (US)
Jona Allison aero - '91 Dodge Ram D-250 Le
90 day: 20.76 mpg (US)
Update
Went to set up a test . 5 gallons of water ~34°f and was going to time the heat transfer and fule consumption. But the included "$200"doseing fule pump was not sent. So instead of running the device I disassembled it to function test each component separately.
It was listed as "Brand New" . Rust stains, diesel soot, and a locked up water pump (was easily freed as a single component,but would likely have burned out if left alone) indicate a miss leading listing.
Forced air fan checked out
Limit switches checked out
The glow plug was able to exceed 500 °f (the high limit of my IR temperature gun) in 30sec on a 12vdc1200ma wall wort power supply.
Called the Manufacturer and they said the way the wiring harness was setup, "the on-bord controller is most likely fryed". They have the diagnostic wire jumped to ground.
And that this particular unit is a military specific unit with classified parts listing. (read some parts not available to joe public)
Waiting on a response from the seller.
Most likely the system will be returned.
I've seen other 12vdc heaters listed for less $
1st gen cummins 91.5 dodge d250 ,HX35W/12/6 QSV
ehxsost manafulld wrap, Aero Tonto
best tank: distance 649gps mi 24.04 mpg 27.011usg
Best mpg : 31.32mpg 100mi 3.193 USG 5/2/20
Former
'83 GMC S-15 Jimmy 2door 2wd O/D auto 3.73R&P
'79 Chevy K20 4X4 350ci 400hp msd custom th400 /np205. 7.5-new 14mpg modded befor modding was a thing
87' Hyundai Excel
83 ranger w/87 2.9 L FI2wd auto 18mpg on the floor
04 Mitsubishi Gallant 2.4L auto 26mpg
06 Subaru Forrester XT(WRX PACKAGE) MT AWD Turbocharged 18 plying dirty best of 26mpg@70mph
95Chevy Blazer 4x4 auto 14-18mpg
04 Chevy Blazer 4x4 auto 16-22mpg
