Old 02-11-2017, 05:21 AM   #6 (permalink)
Stubby79
Stubby79's Avatar
Firefly EV - '98 Pontiac Firefly EV
90 day: 107.65 mpg (US)
Little Boy Blue - '05 Toyota Echo
90 day: 33.35 mpg (US)
BlueZ - '19 Nissan 370Z Sport
90 day: 17.19 mpg (US)
Unless its too low of an idle speed (sub 800 rpm) or it's an ancient alternator design, it should charge just fine. Modern alternators can put out almost full power at idle.
BTW, your rattle is probably due to the engine running at exactly the right (or wrong) speed and load to cause the engine to vibrate a bit, making other loose things rattle (heat shields). Could also indicate a broken engine mount. At any other RPM or load (like with the lights OFF), it won't do it.
