That is what i am proposing. An injector to have a precise control of fuel flow. Followed by a hot copper pipe followed by a cooling copper pipe, just as you are proposing. You can add teflon tubing in between to act as heat barriers so hot part of pipe does not contact cold part (or even between the injector). With such a simple system you can test your ideas.
Once the vapor cools down (as you propose) we do not know if the gunk will condemse out, with this setup you can test that.
