Old 02-14-2017, 11:15 AM   #8 (permalink)
Mr. Pancake
Hybrid Pancake - '03 Honda Civic Hybrid
90 day: 56.01 mpg (US)
Originally Posted by samwichse View Post
This is the part for the 2001-2005 non-hybrid M/T shift cable.
54310-S5A-A03
https://www.hondapartsnow.com/parts-...ift-lever.html
I would be fairly shocked if there is any major difference from the hybrid model. The shifter itself is the same (identical part number), and the transmission is only slightly different.
Compare to the 54310-S5b-A01 (Civic Hybrid) here:
Obviously, YMMV. But you should be able to yank a Civic 5MT shifter cable at a pick and pull for peanuts if you wanted to try it out.
I will look into that, thanks.
