Take your truck to a Dodge dealer and have them print out a build sheet, all the alphanumeric codes missing from the glove box . Some can some can't. They should be able to.
St Hellens , Oregon provided me with the print out were as Longview, Washington ~30mi away told me they couldn not even do it for a new truck much less my old 1991.5 .
If they can't call Oregon all they need is the VIN.
Anaconda was able to look up the info. Just was not able to tell me the part# for the large tank option listed on my truck after I put 27.011 ga in , from the trip in my signature.base tank is 27ga but may have the 35ga w/27ga sender.
Cummins Northwest is there in Missoula .
I contacted [url=http://thesensorconnection.com]The Sensor Connection /url] and they said a simple 2pole x throw rotary switch would alow for extra K-Type probes for measuring other Ecomodder type things like IAT /grill block effects. Also the exposed tip probes(quick response) are ok on diesel they will just need periodic cleaning, I'm at 50,000mi with no loss of response speed. They have 2 fast response probes, a 250ms and a 125ms. Standard diesel is 1200ms or 500ms and shrouded. (Fail proof)
98-02 24v was the vp44 . You have the CP3.
Maby swap out the round tube steps for some that are solid like mying, run them all the way to the back tire. 1 ti gives a flat surface th hang skert from. 2 it will help keep the turbulent air under the truck insted of wrecking the flow for the hole lower side of the truck.
Dreem big chisel down to reality.
1st gen cummins 91.5 dodge d250 ,HX35W/12/6 QSV
ehxsost manafulld wrap, Aero Tonto
best tank: distance 649gps mi 24.04 mpg 27.011usg
Best mpg : 31.32mpg 100mi 3.193 USG 5/2/20
Former
'83 GMC S-15 Jimmy 2door 2wd O/D auto 3.73R&P
'79 Chevy K20 4X4 350ci 400hp msd custom th400 /np205. 7.5-new 14mpg modded befor modding was a thing
87' Hyundai Excel
83 ranger w/87 2.9 L FI2wd auto 18mpg on the floor
04 Mitsubishi Gallant 2.4L auto 26mpg
06 Subaru Forrester XT(WRX PACKAGE) MT AWD Turbocharged 18 plying dirty best of 26mpg@70mph
95Chevy Blazer 4x4 auto 14-18mpg
04 Chevy Blazer 4x4 auto 16-22mpg
