Originally Posted by kingster1989
If I remember right, do you tow a fifth wheel trailer or a bumper pull trailer, either way, you could make an aeroshell that could tilt up and become the aero front end for the trailer to keep the air flowing smoothly.
its a bumper pull.
and to other comments... i have trailer brakes. and spent the time to adjust them to the truck. i even pulled the drums apart and adjust.
so i guess theres only one thing to say..... welcome to the u.s.a...
so. after waltzing through home depot without a plan i walked out with 1/2" cpvc, a bunch of tee's and 90's, 4 sheets of corrugated clear plastic and screws.
so far i got halfway done till i got tired. after working all night and staying up through the day... anyway, I'm going to hopefully have it functional by the time i have to go to work tonight. I'm going to have to go back to the local hardware store and get more tee's. i have to build up more support for the middle, and probably use the rest of the pipe i got to make a few more cross supports.
anyway i never pulled out a tape measure. and only had my pocket knife to cut it all... so far I'm pleased with how its turning out. definitely needs some things ironed out. but I'm sure it will make an improvement. ill have to fill the tank up again to see what kind of change it makes.
"20+ from a gas one ton!? INCONCEIVABLE!!!"
-Every other forum i tried to state my intents...
Total spent on mods. :$440($200 was oil. So take it or leave it)
Total returned from 10mpg baseline :$167
miles since i started ecomodding :3315 miles
