Here is some stuff I plan on doing. In no particular order. Most of it is silly fantasy stuff I'll probably never end up really doing, some of it is more pressing.
Mechanical things to do.
Replace front tires. (Done, got 4 Dz102's)
Replace shocks.
Fix oil leak.
Stop belt squeal.
Replace transmission fluid.
Change spark plugs.
Sway bar bushings.
Sway bar links.
Tie rod ends.
Things to do for interior.
Clean interior. (Done).
Dash carpet.
Add Cruise control.
Drivers seat. (Replace/repair)
Steering wheel. (Replace)
Climate control faceplate. (Replace)
Shifter boot. (Replace)
Emergency brake cable cover. (Replace)
Door panels. (Replace)
Speakers. (Replace)
Lube window channels.
Screws/bolts for steering colum.
Trunk lid seal(replace).
Remove roll bar.
Add interior lighting.
Exterior.
Wash and wax paint. (Washed, but not waxed yet).
Remove trunk cargo rack, repaint and add rubber protection for paint.
Fix door locks on both doors.
Replace windshield wipers.
Repaint rims.
Repaint window trim.
Repaint front bumper lip.
