Thread: Another Civic
Old 02-20-2017, 03:19 AM   #6 (permalink)
Gasoline Fumes
Too many cars
Gasoline Fumes's Avatar
CRXFi - '88 Honda CRX XFi
Insight 256 - '00 Honda Insight
Gen-1 Insights
Insight 5342 (no IMA) - '00 Honda Insight
Gen-1 Insights
90 day: 66.3 mpg (US)
Originally Posted by EF Civic View Post
The 1988 Civic transmissions aren't so great because they used that-year-specific clutch & flywheel (input shaft splines are different than the 1989-2000 D series). So I picked up the 90-91 DX trans to have a hybrid one made up: DX 1st thru 4th gear, HF 5th gear & 2.95 final drive, DX casing (better condition), DX input shaft (can use newer/better clutches & flywheels). The DX gears will shorten up driving around town a little bit. The 5th gear will be fantastic at higher speeds on the highways -- about 80 MPH at 2400 RPMs.
Good idea! I hate the HF 3rd gear, it's too tall for climbing some hills where I live. I should've made a hybrid transmission, but instead I installed a junkyard HF transmission with a bad bearing.
2000 Honda Insight
2000 Honda Insight
2000 Honda Insight
2006 Honda Insight (parts car)
1988 Honda CRXFi
1994 Geo Metro
