Old 02-21-2017, 11:40 AM   #7 (permalink)
oil pan 4
They already tried to use a grid tie and a stand alone inverter at the same time on ecorenovator.
The voltage went up to 150v and one of the inverters smoked.
To power up your house with with backup power, a generator or solar power you have to at least have a blocking breaker that simultaneously turns the main off and turns the backup power on, some power companies require an actual transfer switch.
I don't do anything of that, I just pull the meter because the cost is $0.
Plus the utility workers can easily see that the meter is pulled when they notice only one house has the light on.
