Old 02-23-2017, 01:31 PM   #66 (permalink)
cRiPpLe_rOoStEr
Originally Posted by Sparkeysmall View Post
The only reason an automatic is stronger than a manual transmission is because of the planetary gearsets. The internal load is placed more or less radially into the case. Unlike a manual where the gears are trying to push themselves apart, and helical putting a small load lengthwise through the shaft.
That's also true, but I was refering to the coupling. I've already seen more clutch packs damaged under heavy loads than torque converters damaged under the very same conditions.
