Old 02-23-2017, 03:35 PM   #12 (permalink)
Erasmo
Two weels Zero sparkplugs
A proper breaker box should have a main switch between the meter and your house.
I don't recommend using a generator to trick the inverters into thinking that the grid is up, if you do that you have both the generator and the pv pumping 5-6kW in a system where it can't flow back to the net, a recipe for disaster.
Just use the generator and run a few leads to keep the fridge cold and charge your phone. Or perhaps don't neglect your public infrastructure 30 years, grid cost here for an household is about €220 and the average downtime is 20 minutes a year.
The Following User Says Thank You to Erasmo For This Useful Post:
aerohead (02-24-2017)
