It would be instructive to know what all is hooked up, and where is it hooked up with, with regard to an E85 kit. Does the E85 kit require a setup procedure?
I suspect the only things that really get hooked up are power, ground, and the injector connections themselves. I also suspect that there's a lack of any meaningful setup procedure. If this is the case, then I suspect that the E85 kit only lengthens fuel injector pulses by some set amount. And if that's the case, then there's no reason why you could not just use larger flowing fuel injectors, instead.
